Just noticing a issue on my car as it is gettign cold. When its cold out I have issues getting my shifter into 1st & 2nd once the car warms up it shifts great. I dont think its clutch but any ideas what it could be? I was going to try changing the trans fluid as I have never done it (owned the car 4 months)
1st & 2nd gear shifting issues
Tags: None
mine does this sometimes. old tranny fluid would be my guess. but idk for sure.Past: 1987 325iS, Bilsteins - HR Sports
Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount -
Mine does this too, more when cold than warm, but I think it has done it warm as well. I have only had the car for about a month and only driven it about 1,000 miles. I think I will change the fluid soon and see if it helps. Any other tips?Comment
sychros going in 2nd. it's common. not much you can do besides a transmission overhaul, rev match, or get a new transmission.'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
