E28 final drive on e30?
  • E30 331is
    • Sep 2011
    • 1166
    Is there such a thing?
  • LJ851
    • 7919
    Sure, swap the back cover and output flanges and you are good to go.
    Lorin
    The M30 is God's engine.
    • E30 331is
      • Sep 2011
      • 1166
      so it has an e28 diff cover, but how can i tell if its an e30 diff, or is there no difference other than the output flanges and the cover? it has a white S on the body and rotates ~3.75 when i turn the output to 1Xinput.
      • nrubenstein
        • 3148
        flanges and cover. no other difference.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • LJ851
          • 7919
          That is correct, there is no difference. If the tag is sill under a bolt on the rear cover, it will tell you the ratio and if it is a limited slip with an "S". I dont think E28's had 3.73's but i'm not 100% on that. Most E28's had 3.25 and autotragic's had 3.45.
          Lorin
          • E30 331is
            • Sep 2011
            • 1166
            No tag, just the white S and by rotation I figured since its close to a 3.75 its a 3.73 and since it has the e28 cover I got confused not knowing they are interchangeable. So I have a spare 3.73 sitting here... for how much these go for?
              • 37834
              Standard rate I've sold 3.73 LSD diffs for is $180-$220 picked up. These all had E30 covers and flanges of course though.
              Grover Beach, California
              BimmerHeads.com
