Diff swap questions
  • CompleteCustoms
    • 53
    Diff swap questions
    I have decided that I want to swap an LSD into my '86 325 (eta). Based on what I have read I know that I definitely don't want to go above a 3.25.
    Are there any other LSDs between my stock (2.73 ish) diff and a 3.25 that I should consider?
    Also, to save money, I would like to get it from a junkyard. What models came with a 3.25 LSD?
    Thanks
    • 37825
    You could go with a 2.93 LSD which came in the 86-87 325eS.
    The 3.25 LSD came in E24 6 series cars and E28 5 series cars. Most commonly found in the E28 535iS.
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • Gooch
      • Dec 2006
      • 1674
      +1 to the above. Also note that if you get an e24 or e28 diff you will need to swap over the e30 medium case diff cover and output flanges.
      '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
      '87 535i - Vacuum brake conversion [SOLD]
      '93 525iT - 5-speed swap - 320k and counting
      '09 328xi - 6-speed
      • CompleteCustoms
        • 53
        Thanks guys, very helpful. That's pretty specific though and will probably be hard to find, maybe I'll just have to stop being cheap and buy one off someone here.
        • Wanganstyle
          • 2828
          you can buy a much newer diff from a Z3.
          3.07, 3.15, 3.23, 3.46 are all ratios that were on much newer Z3's.
          e30 325E's also had 2.93 LSD. old but not as old as a E24/28 unit.
          the e24/23/28 items are 2 decades old vs 1. Rubber seals, bearings do degrade over time/wear
            • 37825
            So if parts are old they must be junk?
            Santa Clarita, CA
            www.BimmerHeads.com
            • CompleteCustoms
              • 53
              I like the sound of a 3.07 or 3.15, might be a good compromise.
              Is the Z3 diff a straight swap into an e30 or are there other parts I would need?
              If I find a Z3, how can you tell what ratio it is?
              Thanks
              • Jean
                • 18228
                I gotta talk to you soon to see what you have on hand, so I can swap my ratio :)
                • Wanganstyle
                  • 2828
                  the r3v crowd is trying to buy junker diffs for $100 and cheap out on seals. also wonder why the pinion bearing always dies...
                  is it that scary to rebuild a diff and use new seals, new races and new bearings? and new LSD internals??? Just like how piston rings are un-known to 24v swappers.
                  sure, I want to see some V8 powar!!!
                  Thanks
                  If you find a z3 ask him for his VIN number. This will tell you many things; the vin number is usually in the B pillar /door jam area when you open the drivers door
                  the entire Z3M rear end with its diff will PNP into an e30 :) people put e30 diffs on Z3's also; Just figure out what ratio/size diff unit you have and want to go to
