m20 getrag 260 problem
  • e3027sedan
    • 142
    ok so here it goes i was driving around the block yesterday and i was in second gear everthing was normal then i go to put it into first and nothing it acted as if it were in neutral so i shift back to second drive it home and park it....now it wont move i put it into first and second and nothing no noises or anything i try to go into third fourth and fifth and it wont go into any of them it acts as if theres no gears there.... can anyone help sorry if its confusing im just lost thanks for the help if you want you can call me at 253 973 2363
    The first thing to check would be the shifter. Get the car up in the air and see if the shifter is actually selecting each gear.
    • e3027sedan
      • 142
      i did that everything looks fine but im not sure so im going to take it off today and look into it more....
