i got a 87 325is when ever i drive and down shift from 4th to 3rd gear it grinds pretty bad sometimes it does it when i go from 2nd to 3rd but only sometimes, i think its my synchros but not sure im new to this stuff n trying to get into bmws just bought a 87 325is n i love it but the transmission is giving me that problem any 1 got some clues or ideas or tips how i can fix this. thx
synchros
Tags: None
The first actions should be to replace the motor and transmission mounts, rebuild the shifter and change the transmission fluid. If the problem is still present replace the transmission.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
I have a similar problem with my 1st to 2nd but I just end up shifting in the 3500rpm range and the ratios match up pretty good for it to go into gear. Would royal purple help? I changed my fluid out to lucus non synthetic oil about 6 months agoComment
