Greetings, thank you for your help. I have a splitting headache and its late at night so I need to get this stuff in the morning. Now I know that I need cheap gl4 ( lots of them) and lsd gl5 and non lsd gl5( if its necessary) I dont know which is which
I am doing the maintenance on these two vehicles.
1989 325ic with LSD 5mt
1989 nissan d21 2wd truck
Here is the goal. To spend the least possible and have all the right oil.
I do believe that all the e30 oil left over will work in the d21 truck.
1. I already ordered 2 quarts of redline 75/90 w mtl gl4 whatever is left over can go to the truck.
What are the remaining quarts of oil necessary and what are their descriptions? I am going to oreilly and getting the cheapest available or whatever you suggest.
Also tell me what is going to be left over? Do the full word problem.
2/3 credit for just the 2 transmissions, I can go with that.
I believe it called for 90w oil and I dont know what the lsd is i believe 75/90w with lsd.
Transmission Fluid (MTF) HQ Multi 75W-85 OR API GL-4, Viscosity SAE 75W-85
Fluid type:
Standard Differential Gear
Type API GL-5
Viscosity / Temperature Recommendations:
Below 10°C (50°F) 75W
Below 30°C (86°F) 80W
Below 40°C (104°F) 75W-90
OR 80W-90
Fluid type:
Type API GL-5
OR 80W-90
