Necessary to change the tranny oil
  • RH318is
    • 69
    Since I passed the 200k mile mark, I'm starting to consider some maintanance. The tranny oil was changed when I had the head redone at about 120k. Should I change it asap, not be to concerned and change it if I get the chance, or just let it go for a while more?
    Thanks,
  • DaN
    • 1265
    I would definitely change it every 30k.
    Get on it!
    • RH318is
      • 69
      I have some RedLine synthetic I bought a while ago, what's the opinion on putting this in a trans with 200k on it? Better to use regular stock oil?
      • Sean
        • 5793
        I put redline in mine, and it has 216,000 miles on it. Shifts silky smooth. The Getrags go forever, so no worries. :)
        - Sean Hayes
        • erik325i
          • Jan 2005
          • 3567
          Definatley replace the fluid. I use Redline fluid in mine.
          • SpecM
            • Oct 2005
            • 4531
            -What viscosity should be used?
            -Oh, hi erik325. Ive seen you at bf.c
            1989 cirrisblau-metallic 325i
            • RH318is
              • 69
              Ok, any tips on jacking the car? Is just putting the front on ramps ok, or does the whole car need to be lifted?
              This is what I bought a couple years ago, still ok to go with?
              2 qts of each-
              RedLine MTL - 70W80 GL4 for the tranny
              RedLine 75W90 GL5+Hypoid Gear Oil for the diff.
              • Sean
                • 5793
                2 qts of each-
                I can't remember what I put in my tranny. I think I accidently put in 90.
                That sounds right to me, I meant to put MTL in my tranny. The 75W90 goes in the diff.
                I would actually life the whole car. Since you fill the tranny until it starts to flow out, it's a good idea to have it level to the amount of fluid is accurate. Just put all four corners on stands, get a fluid pump ($6-$7 from Schucks, NAPA, etc) and fill'er up.
                - Sean Hayes
