Can anyone provide a DIY for differential gasket and oil change?
How to change differential gasket and oil
Here's the gist of it:
1 Jack up your car and support it.
2 Remove the diff drain plug with a 17mm hex bit or allen.
3 Drain out all the fluid.
4 With drain pan still under the diff unplug the speed sensor & remove the cover bolts.
5 Let the remaining fluid drain out.
6 Clean off the old cover gasket with a gasket scraper.
7 Install new gasket & reinstall the cover and speed sensor.
8 Fill with fluid until it hits the fill hole.
9 Reinstall the fill plug and drop the car down.
10 Do victory donuts while enjoying your new fluid and gasket. -
