Ok I've been becoming a bit OCD about my car...I really want zero vibrations, like even the slightest shake makes me uneasy. I had a driveline vibration that came from the TOB, I knew this because I felt a shitload of vibration in my clutch pedal. I replaced that and I replaced the CSB. The guibo is new as well. The vibration happens at about 60mph, its fairly subtle but enough to give me a little rumble in my seat. There are a few things I can think of that might be causing this: when I put my CSB into place, I kind of had to muscle it in place to stretch the rubber towards the diff- should the CSB line up directly to the CSB mounting point? My trans brace is custom (I have a 24V car), but it's a bit haggard- When I have the transmission level, the trans brace sits at an angle so I have to muscle it into place, as a result the drivers side transmission mount is very squished- perhaps the transmission is shifted at an incorrect angle because of this (new rubber trans mounts btw)? I put new tires on my wheels in August of last year which is when they were last balanced so I think I'm fine in the balanced aspect, but they are not hubcentric wheels, they are just "floating" in place with the lug nuts- perhaps this is what's causing it?
ALSO: I just put a new TOB, but I have a VERY slight buzz, not really a vibration but a little buzz, less than that of your phone on vibrate. Is this normal, or should my clutch pedal not buzz AT ALL?
