trans fluid
  • phucking-low
    • 32
    trans fluid
    I am changing all fluids in my E30 318is, i like to only use Mobil 1 oils. I use full synthetic mobil 1 oil, i got Mobil1 Synthetic Gear Lubricant LS 75W-90 made for limited slip rear ends, now i am trying to find a mobil 1 manual transmission fluid but not having luck. Does anyone know if they make a good transmission fluid that will work in my 91 318is 5spd trans?
    • 37828
    If you're set on Mobil 1, you'll want this:
    The transmission in your car uses ATF from the factory.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • phucking-low
      • 32
      thats automatic transmission fluid, im looking for manual trans fluid.
      • MattAvino
        • Jan 2011
        • 2147
        Your transmission takes ATF. Like MR 325 said.
        E30 buildy things
        http://www.r3vlimited.com/board/showthread.php?t=195286
        • nrubenstein
          • 3148
          And really, you should get over M1. It's mediocre at best these days.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • KenC
            King of Kegstands
            • 14396
            Just find a decent ATF.
            Originally posted by Gruelius
              • 37828
              How about you read my fucking post, thanks.
              Grover Beach, CA
              www.BimmerHeads.com
              • phucking-low
                • 32
                I did, your FUCKING welcome.
