background: I bought a 1990 325i convertible as a DD and 5 hours later i was getting it towed home.
the problem : an extremely loud grinding and clunking noise and feeling whenever i try to engage the car into any gear from a standstill. the car rolls just fine in nuetral and the clutch still feels good.i can actually get it into gear but cant drive it.. the problem grinds until you push the clutch in. it just starts inching forward and then it sounds like an explosion of metal and the rear wheels freak out like there binding and releasing.
originally thought it to be the differential, so i put in a new diff and that didnt fix the problem. so then i turned to the axles or the driveshaft. i took off the exhaust and checked the flex disc and center support bearing which both seemed to be in fair condition. the u joints also looked to be in good condition. i pulled the axles and they have seen better days and felt dry altho the boots werent ripped. i replaced both cv axles and the problem is still there. also, when i had the rear up on jackstands, i turned the car on and put it into gear with the wheels in the air. it went into gear fine and i even got it high in first with no problem. but the second i started applying the ebrake the noise came and i pushed the clutched in to save whatevers left of whatever this is. so the problem is only when theres pressure/tension in the drivetrain. i dont think it can be the trans because it went into gear just fine when it was on jackstands.
i really appreciate any help i can get before i take it to have a shop look at it. thanks
