Solved
Solved
Tags: None
Can all be fixed from under the car...just a bit tight morso if you don't remove the drive shaft
Sent from my Galaxy Nexus using Tapatalk 2Comment
First go under and see what's broken...could be as simple as a clip that broke and caused the rod to come off
order from bmw dealer, won't be too bad. will also be nice and brand new (and the correct part)Originally posted by Nick's e30Is there any sort of quick fix or this or does someone around the athens Atlanta area have one? Im not having any luck in te yardOBD1 M54/M52TU swap as a M50b25
