drive shafts
  • alfie
    • Aug 2011
    • 36
    drive shafts
    hello rev i am here at your mercy once again. tonight my question is wheather the first half of a 5 series m20 drive shaft is interchangeble with a regular e30 one. i ask because i swap my motor recently with a m20 from a 5 series and it came with a 5 series tranny. My original drive shaft doesnt bolt up :(. any help will be greatly appreciated. BTW its a 1989 sedan 325i if that helps.
  • Cabriolet
    • 9620
    the output flange on that transmission can be unbolted and then you can drop the one from your e30 on it.
    Much wow
    I hate 4 doors
    • alfie
      • Aug 2011
      • 36
      i swapped the output flange already but had no success
        • 37834
        The 5 series driveshaft is much longer. There is no reason yours shouldn't bolt up if your car was already a manual.
        Grover Beach, California
        BimmerHeads.com
