best lsd
  • carloserna
    • Feb 2012
    • 207
    best lsd
    what lsd do you guys preffer? for the m20b25 ofcourse and for what reasons? mines making noise and i fear its toast :( so before i get a good working one i want to kno what rev thinks of lsd's. thanks guys
  • carloserna
    • Feb 2012
    • 207
    bump*
    • 89 e30
      • 249
      If you want better acceleration and shitty highway fuel mileage I would go 2.93 if you want it the other way around I would go 4.10
      BIMMER für IMMER
      • carloserna
        • Feb 2012
        • 207
        ^^^bro i was thinking the same thing. i NEVER use the highway so thatd be good for me. thanks
          • 37827
          Umm, you've got things backwards here. A 2.93 would be ultra-long gearing for a 325i. It will give terrible acceleration but better highway mileage.
          I like the stock ratio 3.73 for a M20B25 car.
          Classic BMW Specialists
          Santa Clarita, CA
          www.BimmerHeads.com
          • e30leigh
            • Mar 2012
            • 481
            woops...
            as said before. backward info.
            i tend to lean towards the 4.1 i like the acceleration it gives me.
            ive always used 4.1 in all my cars. to me the economy isnt that bad on it. sure the revs are abit higher. but its making more power at the higher revs. so under cruising you dont need as much throttle to maintain a highway cruising speed. so you have less gas going in.
            • carloserna
              • Feb 2012
              • 207
              so a 4.10 is best best for better pick up and sucky highay milage? i need to be schooled on gear ratios.....-____-
              • e30leigh
                • Mar 2012
                • 481
                higher the number the faster the accel basically.
