Hey guys. i have this "annoying" vibration, its not aggressive but rather a nuisance. It happens after 65mph+ , the furthest I took the car up to is 80mph where it still exists and its gets a little bit more aggresive. I drove the car 250 miles like this and expected my guibo to be destroyed but it still looked new. I've replaced
the pilot bearing
throw out bearing
guibo w/ new 12.9 bolts
Driveshaft bushing
new trans mounts
new CSB
The only things I can probably point out is that the bushing may be installed backwards on the driveshaft. Does anyone know how it should be installed?
there's a SOLID face to it, where the rubber piece is solid with the outer shell, and then there's a less solid face on the other side. I have it installed with the less solid face on the output shaft of the transmission. perhaps this is it?
My collar nut isn't tightened down at all, could this cause problems?
It's not my pilot bearing or TOB, there's no feedback on the clutch pedal.
CSB is installed correctly and has no signs of wearing.....
the pilot bearing
throw out bearing
Driveshaft bushing
new trans mounts
new CSB
