Resurfaced flywheel, do I need a shim?
The hydraulic clutch is self adjusting, so the engagement/disengagement point will be about the same even if you take a good bit off the flywheel. Only if the flywheel was reduced in thickness so much as to run out of slave cylinder travel would there be a problem.The car makes it possible, but the driver makes it happen.
