Hey like the title says. I bought the car and it was rubbing it sounds like against the driveline. And when I move my shifter all the way to te left it rubs also... it's pissing me off. I replaced shifter bushing... But I think it is the long metal piece that holds the shifter that is rubbing. What can I do to diagnose the problem? And fix it. Thanks in advance!
M20 with getrag 260 shifter holder rubs against the drive shaft
1989 BMW 325is (SOLD)
1992 BMW 325IC (SOLD)
1991 BMW 318IS (STOLEN!)
2017 BMW M2 (WEEKEND WARRIOR)(GRIGIO TELESTO RESPRAY, FULL BOLT ONS, TUNE-HPFP AND TURBO UPGRADE COMING AFTER WARRANTY IS DONE)1989 BMW 325IC (PROJECT(2002 FORD ESCAPE (DAILY)2001 BMW 330CI (FOR SALE SOON)
"R3v, being a bunch of cheap bastards that would try to negotiate a discount on a free engine,"Tags: None -
And I forgot to add it only rubs in second and sometimes in 4thsigpic
"R3v, being a bunch of cheap bastards that would try to negotiate a discount on a free engine," -
I would not know. How can I find out?sigpic
"R3v, being a bunch of cheap bastards that would try to negotiate a discount on a free engine,"Comment
This happened to me one time, but it was much worse than you describe. The harmonic dampener on the driveshaft came loose and was smacking against the shifter
This was my first thought too. Are your shift throws short, miata like? When I swapped out my stock shift lever for a Z4 2.5, it rubbed on the harmonic balancer. Removing the harmonic balancer will solve the problem and will not effect the driveline.Comment
Ok. Well I just did a stage three clutch swap and tightened the driveline all the way. So I know it's tight. But are you guys sayin it might be the wrong shifter? Does it say anywhere on the shifter so I can know if it's the right or wrong one? And is the harmonic balancer the big black circle thing that's next to the guibo? Thanks.sigpic
Take off the lower lever arm and bend it. UUC motor werks has pictures if you so desire to look.
I works great to bend with in a vice with a few sockets.
Oh Note UUC no longer has an install guide for thw E30 that I can find on their site.
So again take off lower rod.
Look for where it has been rubbing.
put socket right on scratch marks and two above and smoosh in vice.Last edited by bmwguy325is; 05-30-2012, 11:53 AM.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713Comment
put socket right on scratch marks and two above and smoosh in vice.Comment
^-----Better @ google than me LOLsigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
Ok, i still have that on. So if i take it off it should help? i havent checked underneath the car yet.. i havent had the chance for a few days, but i will look at it tomorrow.sigpic
I was asking if i take off the harmonic balancer should that make the noise go away?sigpic
