cuttin an e34 aluminum shifter down to fit e30?
  • kickinindian
    • 2327
    can this be done it looks like the mount will fit the rabbit ears and the rear mount should bolt up once it is cut i just dont know the length to cut it to i have an early model plate mount so i have no aluminum e30 shifter mounts to compare it to?
  • German Audio Specialties
    • Feb 2012
    • 374
    E34 swap parts are more rare and valuable than the E30 bits, you should trade/sell whatever
    August R3VLimited Special: E3012 "V3" box: $225 shipped
    Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass
    • kickinindian
      • 2327
      i had pulled it off an e34 hoping it would fit since my other shift selector rod broke (i ended up getting it welded) but i was still thinking if i could cut the selector rod and the mounting arm it looks like it would fit i just dont know what length the original e30 aluminum carrier is to cut it to. the reason i dont wanna just trade is 1. i wanna try to engineer something interesting 2. i live a good ways away from anywhere BMW parts are readily available so if this works easily for me bonus!
      • Wanganstyle
        • 2828
        order e30 shifter to match your vin number from blunt. won't be very expensive at all, probably cost less than futzing w/ it
          • 37834
          Have you checked your transmission? Most of the 86 cars had provisions to install the aluminum shift carrier even though they came with the sheetmetal carrier.
          I wouldn't waste time messing with modifying the wrong parts when the right parts are easily available and fairly cheap.
          Grover Beach, California
          BimmerHeads.com
