Cheapest place for Complete CSB?
  • Rugbyfan
    • Jun 2011
    • 286
    I bought a used driveshaft from a 97 M3 to work in my swap (the one I have on my car is on its way out, u-joints). I have to replace the M3 CSB with an e30 CSB. Bavauto lists it for $150! is there anyone else that sells a reputable quality for cheaper?
    I plan on taking the driveshaft with the e30 CSB in hand to a local shop for balancing and CSB replacement.
    What specifically do I need to tell them? I need this CSB mounted backwards and the driveshaft balanced? Anyone know a shop that can handle this in the Savannah, GA area?
    I'd like to do a quick "out with the old, in with the new" on the driveshaft if possible.
    "Broke into the wrong God damn rec room, didn't ya you bastard!"
  • drumad
    • Aug 2009
    • 1700
    steve@blunttech.com
    also, the whole out with the old in with the new idea is completely dependent on how seized that bearing is to your current ds
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • Rugbyfan
      • Jun 2011
      • 286
      Sorry, I might not have been clear, but I already have a running s52/zf swap in my car. The current Driveshaft has play in the ujoints. Therefore I bought another driveshaft. My plan is to balance it, install a new CSB and if needed rebuild u-joints. When it's all picture perfect, I'll take out old driveshaft, and install new one.
        • 37828
        Do yourself a favor and buy either Febi or OEM BMW.
        BMA Parts lists the Febi for just under $30 for a late model E30.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Rugbyfan
          • Jun 2011
          • 286
          BMA doesn't have a Febi for the early model (04/87 build) Blunt has the Febi ($40). Is Febi worth twice the price over Meyle? and is there an arrow on there so I will know how to mount it "backwards"? Thanks!
            Most rebuilt drive shafts will come with a new CSB installed. I'd use the drive shaft you have as a core and get a rebuilt from Drive Line Services (or Bimmerworld.
            • Rugbyfan
              • Jun 2011
              • 286
              but even if I bought a rebuild for a e36 M3 I'd still have to swap out the CSB. I suppose I'll try to find a shop nearby and get a quote. I think if I show up with driveshaft and CSB in hand, a balance and possibly a rebuild would still be cheaper than getting one from Bimmerworld and swapping out the CSB.
                A balance of the drive shaft is only required if the u-joints are replaced, which requires machining of the drive shaft. That is not something I'd want done except by a place that has a lot of experience doing BMW drive shafts.
                Every reman drive shaft I've gotten for a BMW has arrived with a new CSB on the drive shaft.
                • scottinAZ
                  • Dec 2009
                  • 1312
                  febi is worth the extra scratch. The cheap ones are a tighter fit (need to be hammered on more) whereas the febi takes a light tap to get it home. mounting rubber also seems thicker on the febi, which should lead to a longer life.
                  I saved 15% on my Bimmer parts by switching to ...
