We're doing an engine swap in my son's 91 325i and when removing the flywheel, the spacer and flywheel fell off and I want to confirm the order of the components. I've looked at RealOEM, but they only illustrate it with the dual mass which this car does not have.
Can someone please confirm the order of components?
I believe it's
Crankshaft - spacer ring - flywheel - flex/drive plate - torque converter - input shaft
Thanks!
I believe it's
Thanks!
