clutch slave cylinder flex line
  • browntown
    • Jun 2004
    • 3524
    My clutch slave is leaking horribly, and I sourced a replacement. Got under the car for a better look, and the 20 year old rubber hose looks due for a replacement. Is there a stainless braided line available for this, or should I just go down to NAPA and get a rubber replacement? I know UUC makes one for the e36 but I can't find one for the e30, especially an 85 eta.
  • Jordan
    • 12916
    Napa isn't going to have it.
    Its a special metal to rubber to metal line. BMW only part.
    https://mtechniqueabs.com/
    • mrsleeve
      • Mar 2005
      • 16387
      dont you know waht NAPA stand for?
      Never Any Parts Available
      Originally posted by Fusion
      William Pitt-
      • browntown
        • Jun 2004
        • 3524
        thanks, looking at the etk it would appear that's an expensive BMW only part too (if I'm looking at the right part -- I'm never sure with the etk). maybe it doesn't require replacement that soon.
        http://www.realoem.com/bmw/showparts...04&hg=21&fg=10
        20 PRESSURE HOSE ASSY.CLUTCH 1 21521156673 $75.33
        edit found it on pelican for half the price, http://www.pelicanparts.com/BMW/cata...Tclutc_pg4.htm
        • browntown
          • Jun 2004
          • 3524
          Update, while reading the ROUNDEL on the crapper I noticed Korman is advertising a Stainless Steel clutch line for an e30. Might have to try that next time I tear everything apart. Couldn't find it in their horrible web catalog, although it is listed in the price sheet at 59.95$ (even though the ad says 55$). If anyone buys this (it's not that much more than the oem rubber from pelican), please report. Here is a scan
