I have a 1991 BMW 325i. It’s an automatic (I know, I’m a bad person :) ) and has about 170k on it. I have owned it for just over 9 months and have probably driven it only 4000 miles. Just recently I’ve noticed that the car has been shifting a bit different than normal, and so I’m wondering if you guys could help me determine whether or not the car may be developing a transmission problem.
I have absolutely no mechanical/technical experience, so I apologize for not being able to describe my problem in the correct technical terms. However, I’ll do the best I can!
Over the past month or so, I’ve started noticing that the car takes just a little bit longer to shift from 2nd to 3rd. The “delay time” varies from around 1 - 2 seconds, depending on how hard I’m pressing on the accelerator and how long I’ve already been driving. It doesn’t seem to do this from 1st to 2nd or from 3rd to 4th either.
The engine doesn’t appear to overheat, and the revs don’t seem to jump up while it’s trying to shift. To be honest, it sort of feels like the car is momentarily stuck between gears and the car is gliding along for a second before it actually shifts. The delay seems happens every time the car shifts from 2nd to 3rd, as opposed to being just an occasional occurrence.
I’m not sure if its worth mentioning, but the car’s idle is a bit rough, sometimes the exhaust smells like coolant, and occasionally the car has a rough time starting up after it has been driven for a long time. Again, I have absolutely no car experience, so I’m not sure if these are even remotely related to the transmission problem, but I thought they may be worth bringing up. Other than that, the car has had no problems at all during the time that I’ve owned it.
Anyways, sorry for the wall of text. Any input at all is greatly appreciated. Thanks!
