I'm planning to change the clutch on my car very soon so I did some research regarding flywheel resurfacing. I currently have an 06/86 325es which I believe is a dual mass flywheel. From what I've read most shops are not willing to resurface a dual mass flywheel. If I where to use the flywheel from an early model 325e (single mass) I assume I would also need the corresponding clutch kit? Is there any other things needed to convert my flywheel? Also would I need shorter flywheel bolts? Thanks!
Flywheel conversion question 325es (Dual mass to single mass)
Thanks! I just checked realOEM and it looks like the clutches have different part numbers. It also looks like the single mass 325e have different part numbers for the flywheel bolts but according to realOEM they are discontinued. Would I be ok using flywheel bolts from a dual mass 325e?Comment
You probably also need the euro 323i throw out bearing which is a little bit longer to make up for the length. I have a late model eta transmission on my 325i. The eta used a dual mass while i's are single and it required the longer TOB. Otherwise the clutch wont engage.
