What gears do i have?
  • MattTHEe30GURU
    • Jun 2012
    • 388
    Im driving at like 65-70 mph and it revs at 3100-3200 rpm. What rear end gears do i have?
    Originally posted by fronton
    He must have been staring right the pole, all the way into it. Happens to me playing mariokart every time.
    1982 F250 Built 351W-sold
    1994 325i-sold
    1987 325es-sold
    1991 318i Slicktop- work in progress
  • lambo
    Captain Scene Points
    • 10953
    I'd say around a 3.73 with an M20. There's a tag on the diff that should tell you your ratio.
    • Rsully70sev
      • 2391
      3.73 is my guess.
      Model? Motor?
      • FunfGan
        • Jan 2011
        • 4958
        Ironic name is ironic.
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • Rsully70sev
          • 2391
          Lol
          • woodisgood
            • 1087
            This calculator is designed to give you a rear end gear ratio.
              • 37834
              So should we assume you have a 1984 318i with an auto transmission?
              Or is it a 1991 E30 M3 with a 2.5L stroker and a dogleg trans?
              Maybe it's a 325e with a 454 Chevy big block?
              Grover Beach, California
              BimmerHeads.com
              • FunfGan
                • Jan 2011
                • 4958
                I very much like the 3rd option.
                Go here be happy!
                • 325ix
                  • Aug 2009
                  • 7783
                  I'll take option two or three.
                  • MattTHEe30GURU
                    • Jun 2012
                    • 388
                    no i have a 91 318i 5 speed all stock. and there was no tag on the diff
                    1994 325i-sold
                    1987 325es-sold
                    • Quadrajet
                      • Jul 2008
                      • 1278
                      You should have a small case 4.10, or is it 4.11? I have noticed on my 318is that my speedo reads about 5mph slow, but my odo is dead-on, have you verified yours?
                      • MattTHEe30GURU
                        • Jun 2012
                        • 388
                        no my odo is non working and i have noticed that the speedo feels or looks alittle slower
                        1994 325i-sold
                        1987 325es-sold
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          speedo indicates speed at the diff, not your traveling speed. It will read correct. If you are going faster than the speedo says, your tires are a bit big. Use your phone's GPS, or a standalone GPS to tell you your speed.
                          • FunfGan
                            • Jan 2011
                            • 4958
                            That seems low for a 4.10 on an m42... I wasp pulling ~3500 @ 70mph.
                            Go here be happy!
                            • ButtJuice
                              • Dec 2009
                              • 2609
                              Its a 3.73. My dad owns a 91' 318is and swapped a 3.73 lsd, that RPM rate is close to his.
                              1991 318is - Sold
                              1986 325 - Sold
                              Instagram - Lamoursum
