E30 rear end question....
  • marakka
    Euro Parts Pimp
    • Apr 2005
    • 2036
    I was at my parts guys' garage today and he claims he's got a 3.91 posi rear end? POSI???? 100% lockup? WTF?!??!?!? Identifiable by an "S" on the top of the casing he says..... I don't speak german great, but I swear thats what he said.. So is this something I should jump on as its a rare piece or is it a fluke?
    • 37828
    It's a Limited slip
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • E30godz
      • 1524
      could be a vicous rear end from an iX, there the only ones i remember with something like that
      but 100% lockup? dont think so.
      • Rob
        • 8166
        Originally posted by MR 325
        It's a Limited slip
        si senor
        BEERTECH
        • erik325i
          • Jan 2005
          • 3567
          Some people reffer to limited slip diffs as posi. All of the LSDs have the S on the casing.
          I don't know if the 3.91 was offered on anything other than "IX"s in Germany, but over here the only think that came with that ratio was the 325ix. Also, it is not a standard clutch limited slip. It is a Viscous LSD.
          • marakka
            Euro Parts Pimp
            • Apr 2005
            • 2036
            I gotta look more into this.... it seems like it would be a LSD but he knows his shit.... Its a euro rear end so I guess anything is possible....
            • marakka
              Euro Parts Pimp
              • Apr 2005
              • 2036
              ok.... explain viscious to me?
              • erik325i
                • Jan 2005
                • 3567
                Well, I don't know all of the exact details, but instead of using clutch packs like most of the other LSDs, the viscous diff used fluid. I don't know exactly how it works though, or why the IX got the viscous diff...
                • redhatpat
                  • Aug 2005
                  • 656
                  The term "Posi" is short for "Posi-Traction", a Chevy marketing word for a limited slip. Now commonly used to mean a limited slip. Don't get it confused with 100% lockup, a posi doesn't necessarily mean that.
                  • mikeedler
                    • 6707
                    yes there is a dif with 3.91. My buddies maroon american specs 325 has one in it now. they arent all that hard to come by in germany. it is not 100% lockup. you cant even drive that on the street. it would only work on a drag strip where you drive in a straight line only. I am almost positive all"BMW" origional difs only have 25%-which is enough for "normal" hard driving.
                    max, it is probably a visco dif, unless you did see a "S" on it. the visco should have a "V" stamped with ink on the top of the dif.
                    the odd thing is that both 3,91 difs that I have had were small housing difs. meaning there is only 1 bolt on the bottom side of the rear cover. its not as strong, but will still work just fine for "normal" driving. the "V" difs are more wanted, but do you feel a difference---NO. and I have managed to blow up every kind of dif BMW makes, ---no i dont drive hard!
                    • mikeedler
                      • 6707
                      and by the way-- i want those side skirts now!!! (j/k) come by on monday if you have time.
                      • Jarvis
                        • 2132
                        Besides ix's, some UK-spec 325i Sports had 3.91LSDs IIRC.
                        And at least in the US, (early) M10-powered E30s had 3.91's. But those were small case obviously and I'm not sure how common LSD examples were.
                        • joshh
                          • Aug 2004
                          • 6195
                          A differential splits the engine torque two ways. Find out how a differential works and see diagrams of differentials in front-, rear- and all-wheel drive vehicles.
                          That's a great read for anyone needing to know how LSD's and differentials work. Good stuff. If you keep going it starts talking about LSD's
                          "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                          ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                            • 37828
                            Exactly!
                            Genreally a diff with 100% lockup is called a spool
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • marakka
                              Euro Parts Pimp
                              • Apr 2005
                              • 2036
                              Its got the s stamped on the top. Seen it.... but he was going on and on about it in german that I couldn't understand. Only thing I got was 100 percent and he spun both sides. I dunno.... I'll get an interpretter over there and ask him. He's got more knowledge than I do about all this euro stuff.
                              So.... if the 3.91 came out of those cars.... where did this 4.46 come out of that I have? its a big case diff so I'm completely lost on that one. I know they offered way more options here in Germany than stateside as you can get a 2.71 here and not stateside.
                              If V diffs utilized fluid to make them LSD then they'd do some hydraulic stuff..... don't see where that would be more desirable... but anythings possible I guess.
