Someone help me!!!!!! ASAP!!!!!!!
  • slaterd
    • Jul 2011
    • 1731
    I need to know the exact specs on the socket needed for the 325e axle retaining nut. Does it need to be a 30mm hex thin wall or can I use a thick wall?!
    Someone please help me
    Originally posted by Wh33lhop
    This is r3v. Check your vaginal sand at the door.
  • Jon Merck
    • Jan 2009
    • 107
    I just checked my 91 325i, thin wallsocket. The thick wall impact type wont fit...I know you have a E, I think they are the same? Maybe someone can confirm... hope this helps.
    89 e30 M60B40 6spd
      A thin wall six point socket is what you need.
