Hey guys,
I need to replace the driveshaft seal on the transmission and I am trying to figure out what transmission fluid to purchase. I was going to order it from BMW, however they keep telling me I am supposed to have a sticker on the transmission that will tell them something. There is nothing there but a vin # sticker which they say doesn't help.
The car is a 1990 and was originally converted from an Auto to a manual, according to the vin # the manual transmission came from a 1990 as well.
AllData states that if there is "No Label" than it is GL4 fluid for the transmission.
Also, I need to replace a seal on the differential and the previous owner told me he filled the rear differential "with the newer, expensive M3 differential fluid". After some research it seems it is the SAF-XJ, however there is also the SAF-XJ-FM .. and I am not sure which to purchase.
He said he changed the fluid to this one after the diff started making some noise. Ive heard the noise myself a few times, very annoying metal on metal sound, thought it was the brakes at first. It only happened a few times and only for very short periods of time.
So, which fluid should I purchase?
