If I swapped a motor, motor wiring harness, ECU and 5spd from a 90 325i 5 spd into an 89 auto and did not modify any wiring before trying to start for the first time would it cause the red/yellow wire going to the white relay in the aux relay panel in the eng compartment to burn up?
I tried starting the motor before remembering I had to splice the park switch wires, when I turned the ignition on white smoke poured from under the white relay next to the 2 yellow ones in the aux relay panel. The wire that burned up was red with a yellow stripe, it went into the same hole as a red wire with a blue stripe? On the auto wiring harness for the car the red with yellow stripe wire is not present, only the red with blue stripe.
Do I need to use the original wiring harness from the auto car or should my manual wiring harness work? Did it burn up because I did not splice the wires together and tried starting the car? Or am I facing a bigger issue with a ground or something somewhere?
Please help. Phone calls excepted. 614.725.8482
Thanks
Thanks
