Compatibility question 318-325
  • Mastrcruse
    • Sep 2005
    • 5340
    Found a wrecked 91 318 5 speed. Are the master cylinder, clutch pedal, pedal set, clutch lines the same as the 325? Since the 318 uses a different tranny I'm guessing the slave cylinder isn't the same right?
    Thanks
    I think those parts are the same on both models. You can compare part numbers on realoem.com
      • 37834
      Yes, they will interchange.
      Grover Beach, California
      BimmerHeads.com
      • Mastrcruse
        • Sep 2005
        • 5340
        Thanks guys.
