Early G260 in a late model
  • ButtJuice
    • Dec 2009
    • 2609
    Can this be done correctly? If so, what needs to be modified?
    Thanks for the help.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
  • frankie591
    • Feb 2012
    • 545
    same trans
    • ven0m43
      • 24
      I've read there are different mounting holes.. or brackets, or something. Anyone??
      • frankie591
        • Feb 2012
        • 545
        same mounting holes. the mounting holes didnt change ever, thats why you can mount a g260 up to an m20, m50, m52, m54 etc.
          But early I'm assuming the transmission came from an ETA. In which case there will be holes in the bell housing for the ETA timing sensors and it won't have the ears for the aluminum shifter console. The holes can be plugged and you can get the adapter for an E30 M3 to use the late shifter.
