Weird Rattle from 6000 - 6900RPM
  • James Crivellone
    Head Janitor
    • 6305
    Hey guys,
    With the rain/snow done for a few days I decided to drive the car to work.
    I noticed a weird noise when I was at WOT around 6000 - 6900 coming from the transmission area, it sounds like a rattle/bearing rattle. Gear does not matter.
    It does not make this noise below that RPM, the Clutch and Transmission are working fine witout issue.
    My car does have that typical input shaft noise when it neutral, although most e30's I have seen have that noise.
    Any thoughts?
  • Brew
    • 3060
    Probably a heat shield.
    '91 318is
