How should I clean my diff?
  • ehlpitel
    • Dec 2004
    • 118
    There was a pool of oil under my diff and I need to clean it up real good to see where the leak is coming from to see if it's crakced or if one of the seals is leaking. So I'm curious what kind of stuff you guys would use to clean the diff, brushes, solutions, etc. Thanks in advance.
  • onenicebimmer
    • 139
    wire brushes work well, and you can always polish it off with some brake cleaner and shop towels.
    • kencopperwheat
      King of Kegstands
      • 14396
      Castrol Superclean
      Originally posted by Gruelius
      • ehlpitel
        • Dec 2004
        • 118
        Is it possible for a fucked up central support bearing to burst the input seal on the diff? And how bad is it to drive with a bad central support bearing?
        • blunttech
          • 12850
          its not likely but it wont do it any good. if you can hear that your center support is making noise it needs to be fixed. 1 worn component puts stress on all related components. fix it as soon as possible
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • ehlpitel
            • Dec 2004
            • 118
            It broke when i was round 50 miles from home and I'm not about to tow this car unless it's absolutely needed, so I drove it for a little while. Since I didn't get around to fixing it right away, I've had to drive it around the block a few times a month to keep it normal and all, that's when there was a leak.
            • 88325isboy
              • Mar 2004
              • 1058
              Greased lightning!
              '87 325 (Track Rat)
              '04 C5500 Wrecker (Work)
              '94 525i (Daily)
              '90 325i (R.I.P)
              H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
              • wastedincome
                • Aug 2004
                • 906
                I really like the Degresser from Home Depot, comes in a 1 gal jug (May have 5 gals too) purple colored, Made by ZEP if I recall. Some good shit
                That Greased Lighting is some awesome shit too but kinda Expensive
                Wastedincome420@yahoo.com
                CURRENT STOCK LIST:
                00' e38 750iL HighLine=Highway Queen
                92' e30 318 vert=Aint going anywhere
                91' e34 535iM=Aint going anywhere
                91' e34 525iA=For parts
                92' e34 535iA=For parts
