Auto Transmission shifts Manually, but not Automatically?
    Hi all.
    I have an 89 325i Auto Sedan.
    Since I purchased it 6 months ago, the car would bog off the line.
    I thought the transmission was slipping.
    But then I learned that if I manually shift through the gears like a manual trans, the car performs great.
    But if I set the selector in D, the car starts in the last gear.
    If I start in 3, the car starts in 3rd gear, etc.
    The Transmission does not seem to reset or downshift back to 1st gear on its own.
    I bought a used ZF 4HP22 with low miles to replace mine, but then I learned about the shifting manually 'work-around' and have been driving around like that.
    Hopefully it is a sensor or something external on the Trans.
    If not, I have the replacement.
    Any thoughts?
    Thanks.
    "Drive like you mean it. Commit."
    "Progress Fervently."
    check the kick down cable.
    It is attached to throttle body.
    -Andy
      I remember reading about this happening in a land rover but dont recall the cause, I SEEM to remember that you need to learn to love your new auto/manual or swap in a different trans because you cant fix it. Google around
        This.
