Clutch pedal low
  • Lyrred
    • 391
    Clutch pedal low
    My clutch pedal is engaging very low to the floor. There seems to be no leaks because my master cylinder is still full. It started this about a week ago. The first day, it came all the way back up to full position. Now it never comes back up.
    I changed my slave cylinder over a year ago with a brand new one so i doubt this is the problem.
    Please help.
    Please excuse the dirt and other imperfections
  • Sindako
    • Nov 2012
    • 116
    Mate Go To A Mechanic Around you With a Lifting Jack and tell him To Re-Set Both of The Clutch Pumps/Piston Cylinders .
    It'll get back as it Was .
    • Lyrred
      • 391
      Thanks for the reply but i'm in the Bahamas. There aren't many mechanics around here that do well with bmws, and if they do, then i'll get raped with cost.
      I do every thing to my car so i can do what i need to do. If possible, can u tell me how to do this? I'd greatly appreciate it
      • frankie591
        • Feb 2012
        • 545
        You could have gotten air in the system even if the reservoir is still full. Try rebleeding the clutch and make sure the bleed screw is tightened properly.
          Since the car has a fairly new slave cylinder, either there is a problem with the clutch pedal or pedal box or the master cylinder is bad. Well, there could be a problem inside the bell housing. But start with the easier stuff.
          • KVF
            • 297
            ^ +1
            I'd start my day with a visual inspection of the pedal/box set up.
