My '87 325 (eta) has had an intermittent knocking sound from the rear since before I bought the car. The previous owner attempted to swap an axle but couldn't get the replacement in (probably bad splines on a rebuild), so he put the original back on. That was 3 years and 40k miles ago. Here are the symptoms:
-Dave
- Rhythmic hollow knocking sound connected to road speed, somewhat like dropping marbles into a can.
- Sounds like it's coming from the rear; my wife rode in the back seat and narrowed the sound down to the right rear.
- Pushing in the clutch silences the sound.
- Usually happens when coasting in a lower gear (1st-3rd), but in the most recent iteration it is occcasionally knocking on acceleration.
- The noise tends to get slightly worse when turning right.
- The noise will stop for several hundred or thousand miles before returning. Changes in outside temperature and driving patterns (highway/city) have sometimes caused the noise to stop or return. It's usually worse in cold weather.
-Dave
