In preparation for my s52 swap I have been trying to find a clutch setup. I will be using the getrag 260. From what I have read you want to use the getrag Flywheel, PP, and disc correct?
If that info is true then I am going to resurface my existing flywheel that has been machined down to around 14lbs.
I have been looking into the spec stage 2 and I have been hearing things about the F1 clutchs as well. What torque rating should I go with as well? Thoughts and recommendations, car is semi daily but definitely beat on. Thanks guys!
