will this driveshaft trick work?
  • J.Rizo
    • Aug 2012
    • 949
    my end goal is to have more play in my engine (i have it on an engine hoist) because i'm having trouble lining something up.
    i found a write up and i have to disconnect alllll kinds of shit. BUT i was wondering if i only take off the four bolts that keep the drive shaft to the diff if that will give me a good amount of play to move my engine more freely?
    as opposed to removing the entire exhaust, dropping those braces, buncha other shit, and then removing the drive shaft.
    any ideas, comments, suggestions, or advice is appreciated! thanks guys.
    oh and my cars a vert if that makes a difference for any of this.
    @joshua.j.rizo
    Originally posted by SpasticDwarf
    Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
    BUY MY BUGATTI WHEELS:
    http://www.r3vlimited.com/board/showthread.php?t=377693
    WRITEUP TO MY RHD SWAP:
    http://www.r3vlimited.com/board/showthread.php?t=371904
  • Roysneon
    • 4505
    The driveshaft is still connected to the trans, which is connected to the body via the trans mounts and the CSB is also holding it to the body. The studs that connect the shaft to the diff are also still into the diff input flange so you'll gain negligible amount of play anywhere. What are you trying to do?
    Originally posted by mbonanni
    I am a pursit now.
    • LJ851
      • 7918
      This. Also the shifter carrier is bolted to the body as well.
      Lorin
      The M30 is God's engine.
      • J.Rizo
        • Aug 2012
        • 949
        my engine brackets aren't mounting up to my motor mounts. no matter where we lift it from, no matter which way we pull or shove, no matter what else we lift, we can't align it.
        when we lift it high up it aligns, but its lifted like three inches above it. when we drop it it just goes forward and down not just straight down.
        so, with THAT said, any advice?
        @joshua.j.rizo
        • J.Rizo
          • Aug 2012
          • 949
          still need advice! i'll be trying again this weekend.
          @joshua.j.rizo
          • Roysneon
            • 4505
            Did you have the arms off? Sure they're not on backwards? Try removing the bottom nuts from the mounts. With everything loosened off (mount arms and motor mounts) you should have enough wiggle room. Just make sure you don't have the arms too loose and mess something up when they hold weight.
            I am a pursit now.
