I am putting my transmission back up to the engine and it is not sitting flush with the engine should I just push harder? Any tips? It says I'm not supposed to bring them together with the bolts and that's starting to look like a good option for the last quarter inch
connecting trans to engine
Tags: None
Do not use the bolts to pull the trans to the bell housing. If you have to do resort to that, then your clutch disk is probably not aligned properly.
Double check your clutch alignment if you try that Jlevie said, without luck.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.Comment
