Selector Rod Coupling Washer
  • SlamedIAm
    • May 2011
    • 318
    I removed the selector rod coupling to replace the selector rod seal on my transmission and there doesn't appear to be a washer inside or if it is it is too deteriorated to be recognized.
    I didn't plan ahead for this aspect of the repair and don't have a new washer on hand. I need to be able to be on the road by Sunday so I would prefer to not be delayed by ordering parts. If I were to reinstall the coupling without the washer would I be risking serious problems?
    In addition, does this coupler need to be lubricated/greased? It was extremely oily when I removed it but the transmission was leaking so I'm not sure if that is intentional.
    The washers should be present, but it will be okay without them for a while. The shifter doesn't require lubrication.
    • AndrewBird
      The Mad Scientist
      • 11898
      It's not so much a washer as it is a foam spacer. All it does is put pressure on the coupling so it doesn't rattle and removes any slop/play.
