m10 getrag 240 shift linkage length?
  • SA E30
    • 1248
    I need some help here.
    I just would like to know if any of the shift linkages are the same length as the one in the M10 powered e30's running a Getrag 240?
    Even if they are slightly longer that would help a bit too, as I'm looking to pick up a DSSR and I'm not sure which would be the best.
    I must also add that I have a sort of home brew DTM chassis mounted shifter using an early model shift carrier modified and mounted to the trans tunnel.
    • 37829
    The selector rod is the same between the M10 E21 and E30 but nothing else.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • SA E30
      • 1248
      I'm more curious to know if the m20 getrag 260 linkage is longer, and how much? I assume it should be straight like the m10 one.
        • 37829
        The M20 selector rod is shorter.
        Grover Beach, CA
        www.BimmerHeads.com
