I am trying to diagnose a vibration issue on my automatic 1984 325E 2 door. So far I replaced the tie rods and upper and lower control arms. With the front end in the air, grab the wheels. Now there is NO movement sideways or up and down. I tried to look at the drive shaft next. Looking forward I can see where the drive shaft enters the transmission and I don't see a guibo. It is hard to see without dropping the exhaust and the heat shield but it sure doesn't appear to be there. Next I will check on the CSB and rear half shafts.
No Guibo?
No Guibo?
Steve Corbett
1983 528E Scrapped
1983 528E Sold
1984 745I
1984 325E - Sold
1989 325I Bronzit-Sold
1989 325I Zinno
1988 635CSITags: None -
It might have the vibration damper covering it. Make sure you check the U joints for play, if they are toast it will cause a vibration.84 318, 86 325ES, 85 325E. 89 325IS,
89 BMW 325is Turbo - 8.02@85mph 1/8th
90 VW Golf, 01 VW TDI Jetta
98 VW GTI VR6 - 11.679@117.58mph Timeslip
96 VW GTI VR6 - 7.63@97mph
www.lugtronic.com
