Will small case diff seals work in a medium case?
  • jntar
    • 459
    I recently bought a '91 318is a few weeks ago. I should have checked under the car before I bought the parts, but I didn't. :(
    I bought a rear seal, which I know wont work because its 6 bolt vs 8 bolt. I also bought the output shaft seals because there is a leak. My question is, does the seal for the small case fit in the medium case? I've searched and Im not finding much. I also checked realoem.com and can't seem to track down which car had the medium case to verify.
    Thanks for any help guys!
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    Go to realoem.com, plug in the part number and see what cars that part is used on. If 325e/i/is/ic cars are listed the part will work on a medium case differential.
    • jntar
      • 459
      I did that and it basically lists everything but the 325is/es.
      E30: Details on E30
      E30 325e Sedan
      E30 325e Coupe
      E30 325i Sedan
      E30 325i Coupe
      E30 325i Convertible
      E30 325ix Sedan
      E30 325ix Coupe
      E30 M3 Coupe
      E30 318i Convertible
      E30 318i Sedan
      E30 318is Coupe
      M42 turbo build.
      • b*saint
        • 3794
        Same seal works in anything of a 318ti also.
        Ma che cazzo state dicendo? :|
        • SkiFree
          • Jun 2011
          • 2766
          All the way back to the 2002, small case diffs all use the same rear gasket. It will not work on the medium case.
          ADAMS Autosport
          • b*saint
            • 3794
            Is he talking about the cover gasket or the shaft seal? I know first hand a E30 diff shaft seal fits and e36 small diff. I use them interchangeably without issue.
            I am not talking about the cover gasket.
