Lately my car has the symptom of a bad slave. With the clutch fully depressed I can't get into gear without really jamming it in. It's just been getting worse. The brake fluid level is fine.
Sometimes it works for a shift or two and the majority of the time it doesn't. When it works the clutch engages literally a centimeter from the floor. This seems like the clutch is not being disengaged even with the pedal fully depressed.
Since the brake fluid level is fine, why would this work fine randomly? Is this a clutch fork issue or a misaligned slave? Car drove fine for a year and this came out of the blue. Just fyi the trans fluid has no history so I couldn't even tell you if it was low or good.
