So, is it my Driveshaft or Differential?
  • wasabinuki
    • Jan 2010
    • 117
    Over the past 6 months this problem has progressively been getting worse, and I've reached the point to where I need to fix it. The sound is speed sensitive and gets louder/faster at speed. There is also a slight vibration in my steering wheel, but I think that's from my front wheels. Check out the video and let me know what you think it could be (:25 second mark you really hear it good):
    Within the last 2 years I have had rebuilt axles and wheel bearing installed, so I doubt it's either of those causing the problem. I also installed a used 4:10 LSD, which was clean inside when I put it on 20K miles ago (I have not looked in it since). My guess is the drive-shaft and/or the differential are the culprits. If anybody has had a similar sound and can help a brother out I'd appreciate it.
    Sounds like differential or transmission to me. But it is really difficult to diagnose sounds long distance. Take the car to a BMW shop and have a pro diagnose it.
    • e30rapidic
      • 2167
      check diff and trans fluid level
      '87 325ic, powered by S50.
