Revshift flex disc
OEM e30 drive line
S52 and zf transmission
New CSB
UUC e36 trans mounts w/reinforcement cups
E28 engine mounts
U-joints are fine
Driveline marked and matched correctly when reinstalled
Installed everything and went for a drive and completely tore apart my CSB. There was an extremely loud banging when I drove it so I pulled it back into the garage and then noticed the CSB. Replaced it and made sure everything was tightened down. The car is up on stands so I can watch the driveline while the car is in first with back tires spinning. The driveline at the CSB is spinning roughly half inch out of true.
Read how a few guys shim their trans so I took off the reinforcement cups to see if that was causing the bad alignment. Seemed like it made it a little better but the car is in no way drivable.
Any suggestions? With the amount of how untrue my driveline is, there has to be something completely wrong. I'm thinking my trans is still sitting at the wrong angle and I need to loosen my engine mount bolts so the trans can sag down more to match up the the crossmember better.
OEM e30 drive line
New CSB
E28 engine mounts
U-joints are fine
