Put new Revshift motor and trans mounts the race poly mounts. Also aluminum and poly guibo. On the throttle the whole car shakes like there is snow in the wheels. It's not speed or rpm related because after you lift off the throttle it stops shaking as violently. I've driven the car 3 times and I'm sick of it. I've never heard a racing car make these noises. Maybe something is out of balance or something is worn. Any help is greatly needed. Thank you r3v friends.
solid motor mount issues
It sounds like the engine isn't running quite right and all of the cylinders aren't firing evenly. That will cause vibrations that the harder mounts transmit into the car, that the OE mount didn't. Find and fix the engine problems and the vibration will pretty much go away. As a bonus, the engine will make more power.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
So after tuning my car, the car shakes a lot less. it is great. but once i get past 80mph, there is a somewhat large vibration. The instruction manuel for the solid bushings said, if there is a vibration at 25 to 40 mph, the center support bearing is bad and needs to replaced. If so is that full day job. Any input would be good. thanks.sigpicDiRTYE30-RALLYE30Comment
