How to tell if it has a LSD?
  • dudecati
    • Jun 2012
    • 104
    Hi - I'm picking up a new to me '91 318is. I've heard that some came with an LSD and some didn't. How would I check if mine has one or not (PO doesn't know). Also, is there any maintenance that should be done to the diff?
    Thanks!
  • navytapaul
    • 615
    Raise the rear and spin the back wheels. Lsd will spin the same direction, open will go in opposite directions
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    • mulletman
      • May 2012
      • 801
      Go find some wet leaves on the road during your test drive. The previous owner will be overjoyed with this behavior.
      • ButtJuice
        • Dec 2009
        • 2609
        Get under the rear and find the tag on the diff, it will say the ratio (most likely 4.10) and if it has an 'S' it's an LSD
        1991 318is - Sold
        1986 325 - Sold
        Instagram - Lamoursum
        • jntar
          • 459
          Crawl under and look for a metal tag on the rear of the differential. It should say some numbers. The letter "S" will be in front of the numbers if it is a limited slip.
          M42 turbo build.
          http://www.r3vlimited.com/board/showthread.php?t=301330
          • James
            • Oct 2004
            • 335
            Do a massive skid on the test drive. Or check the tag.
            • kway
              • 1084
              Crawl under the car and look for an S on the tag.
              Or jack it up and spin a wheel; if the other one spins in the same direction it's LSD, if the opposite direction it's not.
              See, I have all the answers!
              '84 318i - Lapisblau/Schwarz (in cryosleep)
              '06 330i - Titansilber/Schwarz
              • graveshaker
                • Sep 2009
                • 828
                By now many of these S tags are long gone. Do what the first post say if tag is gone.
                • long tall eta
                  • Jul 2010
                  • 1536
                  if it's an is and hasen't been swapped out it will be an lsd. also a 6k clutch dump will tell.
                    By now the only sure way to tell may be the tag (or an S painted on the differential). The clutches in an LSD could be worn to the point that it will behave like an open differential.
                    • evandael
                      • Oct 2009
                      • 2881
                      take it out of the car, take off the cover, and if you can see spider gears inside the diff unit, it's open. if you see a solid clutchpack unit with windows to see the clutches, then it's a limited slip.
                      • CrusherCurtis
                        • 2532
                        Search!!!!!!!!!!!!!!!!!!!!!!!
                        jk
                        • dudecati
                          • Jun 2012
                          • 104
                          Thanks all, appreciate you helping the noob out!
                          • getouth
                            • Jan 2010
                            • 3343
                            only the second part of this answer is true.:)
                            FEEDBACK:
                            http://www.r3vlimited.com/board/showthread.php?t=316212
                            BMWCCA #398608
                            IG @yagayo38
                            "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                            • 88SuperETABD
                              • Apr 2009
                              • 911
                              rev to 4k rpms and let go of the clutch, then floor it! then after you ring it out, slam it to second, then get out and check your tire marks, if theres two its an LSD, 1, Open.
                              (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                              1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
