did I get burned?
    did I get burned?
    seller claims is 373 lsd
    when i turn the input shaft the outut shafts turn in OPPOSITE direction, i opened it up and it appears to be lsd what can cause this?
    Maybe he removed the clutch pack?
    should i be able to see something in here:
    I thought LSD are supposed to turn in opposite directions when you turn the input shaft
    Life is too short to be driving a Honda.
      Should have gears as mentioned.
        i tried it on my 89 325is and they went in the same direction
          it has gears?
            yes... in a nut shell, the limited slip part comes from the clutches pressing against the friction plates and the ramp angle on the diff itself..
            My feedback:
            http://www.r3vlimited.com/board/showthread.php?t=186328
            http://e30tech.com/forum/showthread.php?t=74911
            Instagram:
            @gears_n_glory
            @functionmotorsports
              If it goes in same direction and if doesn't break loose It sounds as thou it might be welded.
                http://www.metricmechanic.com/pdf/Differentials.pdf
                no i was saying the seperate diff in my other car that has lsd the wheels move in the same direction
                on the diff in question the move in opposite directions
                the diff appears to be an lsd and it has the s on the case
                  It could be a limited slip differential with work out clutches. In which case the output shafts may turn in opposite directions.
