Should washers be used on guibo bolt+nuts?
  • noid
    • 1535
    It seems as though 3 of my 6 guibo bolts had washers on them (on the nut side). Realoem only shows a bolt and nut, no washer. Should I ditch the 3 washers?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • FLG
    • Sep 2011
    • 3165
    No washers, youll throw of balance.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • b*saint
      • 3794
      Yea I would only use exactly what bmw used originally.
      Ma che cazzo state dicendo? :|
      • AndrewBird
        The Mad Scientist
        • 11898
        RealOEM shows washers being used, part #6.
        http://www.realoem.com/bmw/showparts...09&hg=26&fg=10
        Balance won't be thrown off because the holes are symmetrical in a circle. And even if they weren't, the weight of a few washers won't cause a problem.
        • SkiFree
          • Jun 2011
          • 2766
          That's actually an error in BMW's ETK program believe it or not. When new they came with no washers.
          ADAMS Autosport
