Whats starter to use on E36/46 S52/54 flywheel
  • FastButBlind
    • Dec 2009
    • 7
    Hi all, am not sure if am posting in the right area!! anyhow.
    Am working on my boosted M50 with 3.0L forged internals, well I got Tilton TO-II 7.5" triple plate, with light weight (3Kg) flywheel to accept the Tilton clutch, as the flywheel made for E36/46 S52/54, so am not sure what starter to use on this flywheel!? I searched for the S50 and S54 starters but I can't find any in the area I live, so what other starter can fit on this flywheel and work without damaging the flywheel?!!
    Thanks in advance guys.
    • 37833
    Starter needs to match flywheel application. So if you're using a S52 flywheel use the S52 starter.
    Grover Beach, California
    BimmerHeads.com
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      Originally posted by mr 325
      starter needs to match flywheel application. So if you're using a s52 flywheel use the s52 starter.
      +1
      -Andy
      • FastButBlind
        • Dec 2009
        • 7
        I know it's better to use S52 starter! whats new!
        But as I said "I can't find S52 starter" so what else I can use!?
        Anyway I already found the answer with Realoem, the S52 starter part number is 12411740379, and when searched on the number, I found this big list
        E30: Details on E30
        E30 318i Convertible
        E30 318i Sedan
        E30 318is Coupe
        E34: Details on E34
        E34 525i Sedan
        E34 525i Touring
        E36: Details on E36
        E36 318i Convertible
        E36 318i Sedan
        E36 318is Coupe
        E36 320i Sedan
        E36 323i Coupe
        E36 323i Convertible
        E36 325i Sedan
        E36 325i Convertible
        E36 325is Coupe
        E36 328i Sedan
        E36 328i Coupe
        E36 328i Convertible
        E36 M3 Coupe
        E36 M3 Convertible
        E36 318ti Compact
        E36 M3 Sedan
        E39: Details on E39
        E39 528i Sedan
        E39 528i Touring
        E39 525i Sedan
        E39 525i Touring
        E39 530i Sedan
        E46: Details on E46
        E46 323Ci Convertible
        E46 323Ci Coupe
        E46 323i Sedan
        E46 323i Touring
        E46 328Ci Coupe
        E46 328i Sedan
        E46 320i Sedan
        E46 325Ci Convertible
        E46 325Ci Coupe
        E46 325i Sedan
        E46 325i Touring
        E46 325xi Touring
        E46 325xi Sedan
        E46 330Ci Coupe
        E46 330Ci Convertible
        E46 330i Sedan
        E46 330xi Sedan
        Z3: Details on Z3
        Z3 Z3 1.9 Roadster
        Z3 Z3 2.5 Roadster
        Z3 Z3 2.8 Coupe
        Z3 Z3 2.8 Roadster
        Z3 Z3 M Coupe
        Z3 Z3 M Roadster
        Z3 Z3 2.5i Roadster
        Z3 Z3 3.0i Roadster
        Z3 Z3 3.0i Coupe
        Therefore I will try my M50 starter and see what happens!
